cancel
Showing results for
Search instead for
Did you mean:
    Fix HP Printer issue in macOS
    A [software component] will damage your computer message displays when printing or while installing - Click Here
    Fix Windows 10 Update Issues
    Resolve Windows 10 or update issues on HP computer or printer– Click Here
Note for common printer problems
Customers receiving the"will damage your computer" message along with others like "unable to access cups/tmp" or "'@%' cannot be opened" need to update their version of the macOS. Please check this article for more information: HP Printers - A [software component] will damage your computer message displays when printing or while installing (macOS) .
New member
4 2 0 0
Message 1 of 4
143
Flag Post
Help with HP Smart Tank 610
HP Smart Tank 610
I have been trying to get this printer working for two days now. Its saying please fill ink? the ink is full I cant get it off this screen. Tried to USB connect to run the trouble shooter but its not recognising the USB connection. Any ideas
3 REPLIES 3
Highlighted
HP Support Agent
HP Support Agent
12,110 12,096 673 503
Message 2 of 4
Flag Post
@Chasey8
Let's try to reset the Printer here:
Reset the product
  • With the printer turned on, disconnect the power cord from the rear of the printer.
  • Unplug the power cord from the wall outlet.
  • Wait at least 60 seconds.
  • Plug the power cord back into the wall outlet.
  • Reconnect the power cord to the printer.
  • Turn the printer on. HP recommends plugging the printer directly into a wall outlet.
Also, try connecting the Printer to a different wall outlet directly.
Try a firmware update: https://support.hp.com/in-en/document/c02919168
Let me know if this helps.
If the information I've provided was helpful, give us some reinforcement by clicking the "Accept as solution" button, that'll help us and others see that we've got the answers!
Thanks!
Have a great day!
I am an HP Employee
0 Kudos
Highlighted
Author
New member
4 2 0 0
Message 3 of 4
Flag Post
I have done several soft reboots i have found the menu function and tried partial reset and semi full reset. I have opened and closed the ink pots several times, I have tried USB and wireless connection,  Sometime it will just print the items in the print buffer but the error wont go away. Then Ill try and print something new and it says Printer in error mode. The display either askes me to replace a cartridge? It has no replaceable cartridges? Or it askes me to fill the cartridges? The cartrdiges are full as you can see in the photo20200729_133551.jpg20200729_133402.jpg
0 Kudos
Highlighted
HP Support Agent
HP Support Agent
15,695 15,690 1,061 1,239
Message 4 of 4
Flag Post
@Chasey8
I understand your concerns, kindly perform the steps mentioned in this document to resolve this issue.
Have a great day!
KUMAR0307
I am an HP Employee
0 Kudos
Warning Be alert for scammers posting fake support phone numbers and/or email addresses on the community. If you think you have received a fake HP Support message, please report it to us by clicking on "Flag Post".
