How to use refurbished ink cartridge for Color Laser jet pro MFP M479FDW
1 REPLY 1
Purchase compliant cartridges that use HP original chips. Many do not because of the expense.
If you find the information provided useful or solves your problems, help other users find the solution easier by marking my post as an accepted solution. Clicking "yes" on "was this reply helpful" also increases the chances that this solution will help others.
I am a volunteer, offering my knowledge to support fellow users, I do not work for HP nor speak for HP.
