    Check documents on compatibility, FAQs, upgrade information and available fixes.Windows 11 Support Center.
Hp Neverstop laser 1001w won’t power on
1 REPLY 1
Any signs of life at all when you try to power up? First unplug the power, and with cord detached, hold the power button for about 30 seconds and then try to start up normally. Did that work? If not, try a different power cord, yes they can fail. Also ensure you are plugged directly into the wall and not into a surge protector or UPS.
If you find the information provided useful or solves your problems, help other users find the solution easier by giving kudos and marking my post as an accepted solution.
I am a volunteer, offering my knowledge to support fellow users, I do not work for HP nor speak for HP.
