Hp printer 4729 power led is not on.and some other leds are glowing study
1 REPLY 1
Hi @Togs1,
Welcome to The HP Support Community.
I understand the power LED on your HP DeskJet Ink Advantage Ultra 4729 is not lit and other LEDs are glowing steadily, it could indicate a power supply or internal issue.
Here’s what you can try to troubleshoot the problem:
Check the Power Connection:
  • Ensure the power cable is securely connected to both the printer and the power outlet.
  • Try plugging the printer into a different power outlet.
Inspect the Power Cable:
  • Check the power cable for any visible damage. If you see any fraying or cuts, you may need to replace the cable.
Perform a Hard Reset:
  • Disconnect the power cable from the printer and wait for at least 60 seconds.
  • Plug the power cable back in and try turning the printer on again.
Check for Electrical Issues:
  • If other devices work when plugged into the same outlet, the issue is likely with the printer. If the outlet is faulty, try a different one.
Look for Error Messages:
  • If other LEDs are on, check if they are flashing in a particular pattern. Refer to the printer’s manual or HP's support website for what the LED patterns mean.
Check for Internal Issues:
  • If possible, check inside the printer for any obvious signs of damage or obstruction. However, avoid opening the printer if it's under warranty or if you're unsure.
Refer to this document: HP DeskJet Ink Advantage Ultra 4729 All-in-One Printer User manual
I hope this helps.
Please click “Accepted Solution” if you feel my post solved your issue, it will help others find the solution.
A_Gayathri
HP Support Community Administrator.
