×InformationWindows update impacting certain printer icons and names. Microsoft is working on a solution.
Click here to learn moreInformationNeed Windows 11 help?Check documents on compatibility, FAQs, upgrade information and available fixes.
- HP Community
- Printers
- Re: I have an officejet pro 6960, and it won't print stuff f...
09-09-2018 03:28 PM
When I bought this printer a couple years ago it worked. But about a month ago, It didn't work.
I noticed the ink cartridges were low, so I bought and installed new ink. Now the printer doesn't say low ink. However, it won't print anything. I want to print stuff from my computer but it won't do that anymore. Why is this happening? How do I fix it?
Solved! Go to Solution.
09-10-2018 05:08 PM
Welcome to HP Forums,
This is a great place to get support, find answers and tips,
Thank you for posting your query, I'll be more than glad to help you out 🙂
I recommend you delete the driver and root level and retry, follow the steps below:
1)In Windows, search for and open Programs and features
2) Select your HP Printer
3) Select Uninstall
4) In Windows, search for and open Devices and printers
5) In the Devices and Printers windows look for your HP printer. If you see it listed right-click on it and choose ‘Delete’ or ‘Remove Device’
6) Open up the run command with the “Windows key + R” key combo.
7) Type printui.exe /s and click Ok. (Note: there is a space in between “printui.exe” and “/s”)
😎 Click on the “Drivers” tab
9) Look for HP Printer driver. If you see it Click on it and click Remove at the bottom
10) Select Ok
11) Select Apply and Ok on the Print Server Properties windows
12) Close Devices and Printers
Once done, follow this link, select the right operating system, and install the full feature driver software. 🙂
Keep me posted,
If the information I’ve provided was helpful,
Give us some reinforcement by clicking the solution and kudos buttons,
That’ll help us and others see that we’ve got the answers!
Good Luck. 🙂
Barachiel
I am an HP Employee
09-10-2018 05:08 PM
3) Select Uninstall
10) Select Ok
Keep me posted,
Good Luck. 🙂
Barachiel
I am an HP Employee
11-28-2018 04:30 AM
New cartridges does all the correct thing but the page cones out blank. Done all the maintenance stuff still nothing ! Any suggedtions
3) Select Uninstall
10) Select Ok
Keep me posted,
Good Luck. 🙂
Didn't find what you were looking for? Ask the community
