HP LaserJet MFP M234sdwe Printer
Error message 75 with flashing !
1 REPLY 1
@Nancydice, Welcome to the HP Support Community!
Thanks for reaching out about your query regarding Error 75 with Flashing Exclamation Mark on HP Printer!
We're thrilled to have the opportunity to assist you and provide a solution.
Error 75 on an HP printer typically indicates an issue that requires immediate attention. The flashing exclamation mark further suggests that the printer is experiencing a problem that cannot be resolved automatically.
Here are some steps you can take to troubleshoot and resolve the issue:
Restart the Printer:
  • Turn off the printer by pressing the Power button.
  • Wait for a few seconds before turning it back on.
Check Printer Connections:
  • Ensure that all cables (USB, Ethernet, etc.) are securely connected.
Update Firmware:
  • Check if there are any firmware updates available for your printer model on the HP website. Updating the firmware can resolve many issues.
Consult the User Manual:
  • Refer to the specific user guide for your printer model for more detailed troubleshooting related to error codes.
  • The manual should help you identify the exact nature of Error 75 and provide specific instructions.
Hope this helps!
Take care, and have an amazing day!
Did we resolve the issue? If yes, Please consider marking this post as "Accepted Solution" and click "Yes" to give us a helpful vote - your feedback keeps us going!
Regards,
ZOEY7886
I am an HP Employee
