HP Ink Tank Wireless 415
Hello.. need help.. whenever i initiate a colored photocopy of my id in my ink tank 415.. the whole page is colored
1 REPLY 1
Hello @Anjomajijoma , how are you ?
Please, try the procedures below:
https://support.hp.com/th-en/document/ish_2281791-2076363-16
I´m waiting
Welcome to the Community, I am a volunteer and private messages will not be answered.
If the answer was helpful and/or you would like to say "thanks", Click on the button“Yes” Did I help solve the problem? Don't forget click “Accept as a solution” , If anyone has the same question, this solution might be helpful.
