The M 608 no longer recognizes letter size paper in tray 2.  I have made minor adjustments to tray guides to see if that was the problem but no joy
1 REPLY 1
Does it recognize legal or other settings?  Do the white tabs move when you change the settings? Easiest way to determine if this is a tray or printer issue is to run the sensor diagnostics from the support menus
If you find the information provided useful or solves your problems, help other users find the solution easier by marking my post as an accepted solution. Clicking "yes" on "was this reply helpful" also increases the chances that this solution will help others.
I am a volunteer, offering my knowledge to support fellow users, I do not work for HP nor speak for HP.
