HP LaserJet Pro M15w
I have installed same driver on both computers, via HP Smart App, connected via USB on both. On Desktop PC it prints sometimes right, but most of the time stops at half, or when I print on both sides and reinsert paper and click the button to print on other side it works only 20% of time. But on my laptop it just works, can anybody help.
1 REPLY 1
Hi @Lukajekic,
I see that you are facing an issue with printing from the PC to your printer.
A) Please follow the steps below to perform a power drain.
1) Take out the cartridges
2) Unplug the power cord from the printer & wall.
3) Press and hold the power button down for 15 seconds and release the power button, wait for about 30 seconds.
4) Plug the power cord back into the printer and wall, ensure the printer is plugged into the wall & not into a surge protector.
5) Insert the cartridges back into the printer.
Remove the cartridges > Unplug the power cord > Wait for 30 seconds > Plug the power cord back in > Insert the cartridges
B) Kindly refer to the steps on this link to update the printer firmware and let me know if that resolves the issue.
C) If the issue still persists, uninstall the printer software by following the steps from this link and restart the devices.
D) Install the printer software by clicking on the link again and let me know if that resolves the issue.
Note: Enable Bluetooth for an HP Smart app setup: Enable Bluetooth on your computer or mobile device so that HP Smart can detect the printer during the setup.
Please mark this post as “Accepted Solution” if the issue is resolved and if you feel this reply was helpful click “Yes”.
I hope this helps.
Take care and have a good day
Irwin6
HP Support
Irfan_06-Moderator
I am an HP Employee
