cancel
Showing results for
Search instead for
Did you mean:
    Know the Benefits of your HP account
    Connect with HP support faster, manage all your devices in one place, view warranty information and more– Click Here
    Fix Windows 10 Update Issues
    Resolve Windows 10 or update issues on HP computer or printer– Click Here
Highlighted
New member
1 0 0 0
Message 1 of 2
52
Flag Post
My printer keeps going offline. I tried fixing it with HP troubleshooting but still can’t get in bac
HP2540 Deskjet 2540 all-one
I have Windows 10 64 bit. I keep losing my wireless connection.
1 REPLY 1
Highlighted
HP Support Agent
HP Support Agent
24,495 24,423 1,629 2,284
Message 2 of 2
Flag Post
@buzzmags
I reviewed your post and I understand that you are facing issues with the wireless connectivity.
Don’t worry, I assure you I will try my best to get this sorted.
I recommend you follow the below steps and check if it helps.
The HP Print and Scan Doctor might get this sorted out
Please download and run the HP Print and Scan Doctor from this Link: https://ftp.hp.com/pub/printers/hppsdr/HPPSdr.exe
Run PSDR
Once the PSDR detects the Printer, it will show up the IP address and Software Status.
Select the correct Printer and click on Next.
PSDR will check if the Printer is on the Network and communication between the PC and the Printer. Once the connection check is done, click on Fix Printing
Once PSDR goes through all checks and automatic fixes, click on Print a test page.
Regardless if PSDR printed the test page or not, click on “NO PRINT”
PSDR will then notify you that there is an update available, click on continue, and PSDR will apply the patch and ask for a reboot.
Post restart the PSDR will run automatically to check for more issue.  If no issue found close PSDR.
Also, try using the HP Smart App and let me know if that helps. Link: https://www.microsoft.com/en-us/p/hp-smart/9wzdncrfhwlh
You can refer to this link: https://support.hp.com/in-en/document/c03561640 for more information on HP Smart App
Let me know how it goes and you have a great day!
P.S: Welcome to the HP Support Community 😊
If you wish to show appreciation for my efforts, mark my post as Accept as Solution. Your feedback counts!
Cheers!
Stay Home – Stay Safe
The_Fossette
I am an HP Employee
Reply
0 Kudos
Warning Be alert for scammers posting fake support phone numbers and/or email addresses on the community. If you think you have received a fake HP Support message, please report it to us by clicking on "Flag Post".
