Need help I don’t have a pass code for my Wi-Fi to connect my ho
1 REPLY 1
Hi @Mzgee,
If you're trying to connect your HP printer to your Wi-Fi network but don't have the Wi-Fi password (passcode), here's what you can do:
1. Locate the Wi-Fi Router:
  • The Wi-Fi password is usually located on a sticker or label on your Wi-Fi router or modem.
  • Look for a sticker with the network name (SSID) and the password (often labeled as "WPA Key" or "Wireless Password").
2. Check Router Configuration:
  • If you can't find the password on the router itself, you can access your router's configuration page using a web browser.
  • Enter your router's IP address in the address bar of your browser (common addresses include 192.168.0.1 or 192.168.1.1) and log in using the router's username and password (usually found on the router itself).
  • Once logged in, navigate to the wireless settings or security settings section to find the Wi-Fi password.
3. Contact Your Internet Service Provider (ISP):
  • If you're unable to locate the Wi-Fi password using the methods above, you can contact your Internet Service Provider (ISP) for assistance.
  • Your ISP should be able to provide you with the Wi-Fi password associated with your account.
4. Reset the Wi-Fi Password:
  • If you're unable to retrieve the Wi-Fi password through any other means, you may need to reset the Wi-Fi password.
  • Keep in mind that resetting the Wi-Fi password will disconnect all devices currently connected to the Wi-Fi network.
  • To reset the Wi-Fi password, you'll need to access your router's configuration page and navigate to the wireless settings section. Look for an option to change or reset the Wi-Fi password and follow the on-screen instructions.
I hope this helps.
Please mark this post as “Accepted Solution” if the issue is resolved and if you feel this reply was helpful click “Yes”.
Rachel571
HP Support
Sneha_01- HP support
