    Windows update impacting certain printer icons and names. Microsoft is working on a solution.
    Click here to learn more
HP Envy 5030
3 REPLIES 3
Hi @Chanelle16,
 I'd like to help!
To better assist you -
1) Does the copy print out the same way?
2) What's the application you are trying to print from? Have you tried printing from a different application or devices?
While you respond to that, let's print a Print Quality Diagnostic page -
  1. Load the printer with plain white paper.
  2. On the printer control panel, swipe left on the display, and then touch Setup .
  3. Touch Tools.
  4. Swipe up on the display, and then touch Print Quality Report.
Post the Print Quality Diagnostic page here so we can help you further.
You may also refer to this document with steps to fix " Print Quality Issues" issue applicable for your printer -  Print Quality Issues
 Also, try updating the printer's firmware - HP Printers - Updating or Upgrading Printer Firmware
And, Welcome to the HP Support Community
Thank you for your reply. Sorry for the delay I have been away. The document was a PDF so no specific program was being used. The setup seemed to go well so we were shocked to encounter the printing issue.
Does the issue occur, when you try and make a copy?
