    Check documents on compatibility, FAQs, upgrade information and available fixes.Windows 11 Support Center.
HP Officejet Pro 7740
I changed out the paper in the 2nd print tray and now it will not close! I am so frustrated. The paper is just 11 x 8 1/2, so no special size. But the second print tray will not close.
@Alfiejay
Welcome to HP Support Community
I would like to help
Please refer to page 14 - 24 in the User Guide: http://h10032.www1.hp.com/ctg/Manual/c05216524.pdf
Thank you
If the information I've provided was helpful, give us some reinforcement by clicking the "Solution Accepted" on this Post and it will also help other community members with similar issue.
KrazyToad
I Am An HP Employee
1 REPLY 1
@Alfiejay
Thank you
KrazyToad
I Am An HP Employee
