Windows 11 Support Center. -
- HP Community
- Printers
- Print head problem
12-17-2024 11:04 AM
Hi @BB1172,
The error code Oxc19a0015 for your HP OfficeJet Pro 6978 printer typically indicates an issue with the printhead. This can be due to clogs, electrical connection issues, or a hardware failure in the printhead assembly. Here are steps you can follow to resolve this.
Reset the Printer
- Turn off the printer and disconnect the power cable from the back.
- Wait 60 seconds, then reconnect the power cable and turn the printer back on.
- Check if the error persists.
Clean the Printhead Contacts
- Open the printer to access the printhead.
- Remove the ink cartridges and carefully lift the printhead out (refer to the user manual if necessary).
- Use a lint-free cloth lightly dampened with distilled water or isopropyl alcohol to clean:
- The electrical contacts on the printhead (gold or copper-colored pins).
- The contacts inside the printer where the printhead connects.
- Allow everything to dry for 5–10 minutes before reinserting the printhead and cartridges.
Reinstall or Replace Ink Cartridges
- Ensure you are using genuine HP ink cartridges.
- Remove and reinstall the cartridges to ensure proper seating.
- Replace any damaged or empty cartridges.
Run a Printhead Cleaning (via Printer Software)
If the error is cleared, use the HP Printer Assistant software or the printer's control panel to run a printhead cleaning cycle:
- Go to Settings > Tools > Clean Printhead.
Perform a Printhead Replacement
If cleaning does not resolve the issue:
- Contact HP Support to order a replacement printhead if your printer is under warranty.
- If out of warranty, consider the cost of replacing the printhead versus purchasing a new printer.
Update Printer Firmware
Outdated firmware can sometimes cause errors:
- Visit HP Support and search for the latest firmware for your printer model.
- Follow the instructions to download and install updates.
Reset to Factory Settings
- On the printer's touchscreen, navigate to Setup > Printer Maintenance > Restore Factory Defaults.
- Confirm the reset and check if the issue persists.
I hope this helps.
Alden4
HP Support
HP Support Community Moderator
