1 REPLY 1
Hello @Joycegrnsbr , how are you ?
I recommend you request technical support.
HP® Service Center Locator - United States | HP® Support
Best regards
Welcome to the Community, I am a volunteer and private messages will not be answered.
If the answer was helpful and/or you would like to say "thanks", Click on the button“Yes” Did I help solve the problem? Don't forget click “Accept as a solution” , If anyone has the same question, this solution might be helpful.
