cancel
Showing results for
Search instead for
Did you mean:
    Know the Benefits of your HP account
    Connect with HP support faster, manage all your devices in one place, view warranty information and more– Click Here
    Fix Windows 10 Update Issues
    Resolve Windows 10 or update issues on HP computer or printer– Click Here
Note for common printer problems
Customers receiving the"will damage your computer" message along with others like "unable to access cups/tmp" or "'@%' cannot be opened" need to update their version of the macOS. Please check this article for more information: "HPxxxxx.framework" will damage your computer" message in macOS Catalina or Mojave .
Highlighted
New member
1 0 0 0
Message 1 of 2
69
Flag Post
Printer Failer problem with either printer or ink
Microsoft Windows 7 (64-bit)
I have an office  pro 8610.
Printer Failer
there is a problem with your printer or ink system
1 REPLY 1
Highlighted
HP Support Agent
HP Support Agent
5,912 5,882 356 392
Message 2 of 2
Flag Post
Hi @,TBone722,
I'd like to help
Please try the below suggestions:-
Reset the product
  • With the printer turned on, disconnect the power cord from the rear of the printer.
  • Unplug the power cord from the wall outlet.
  • Wait at least 60 seconds.
  • Plug the power cord back into the wall outlet.
  • Reconnect the power cord to the printer.
  • Turn the printer on. HP recommends plugging the printer directly into a wall outlet
Update the printer firmware
Updating the printer firmware might resolve printhead problems. Go to Updating or Upgrading Printer Firmware for more information.
Check the carriage for a printhead latch
Look at the carriage to see if it has a latch. The carriage is the part inside the printer that holds the printhead and cartridges. If the carriage does not have a latch (fixed printhead), then the only option is to service the printer.
  1. Open the door to access the cartridges.
  2. Wait until the carriage stops moving before you continue.
  3. Look at the right side of the carriage to see if the carriage has a printhead latch (a handle that can be raised, which allows the printhead to be removed).
    • If your carriage has a printhead latch, continue to the next step.
    • If your carriage does not have a printhead latch (fixed printhead), skip to Service the printer. If the printhead is fixed, then there are no additional troubleshooting steps available.
Example of a carriage with a printhead latch
Example of a carriage without a printhead latch
Animations of carriage with a printhead latch
Carriage without a printhead latch
Reseat the printhead up to three times
You might need to reseat the printhead up to three times.
  1. With the printer turned on, unplug the power cord from the rear of the printer.
  2. Lift the carriage latch, slightly lift the printhead, lower the printhead back into the carriage, wiggle the printhead left and right, and then lower the carriage latch to lock the printhead into place.
    Animation showing how to reseat the printhead in the carriage
  3. Close the cartridge access door.
  4. Reconnect the power cord to the rear of the printer.
  5. Wait for the printer to start, and then look for the error.
    • If the error message persists, repeat the steps to reseat the printhead up to three times.
    • If the error no longer displays, you are done.
And, Welcome to the HP Support Community.
Click the “Kudos, Thumbs Up" on the bottom right to say “Thanks” for helping
Reply
0 Kudos
Warning Be alert for scammers posting fake support phone numbers and/or email addresses on the community. If you think you have received a fake HP Support message, please report it to us by clicking on "Flag Post".
