cancel
Showing results for
Search instead for
Did you mean:
    Know the Benefits of your HP account
    Connect with HP support faster, manage all your devices in one place, view warranty information and more– Click Here
    Fix Windows 10 Update Issues
    Resolve Windows 10 or update issues on HP computer or printer– Click Here
Highlighted
New member
1 0 0 0
Message 1 of 2
51
Flag Post
“Printer Failure problem with printer or ink system “
Hp officejet 6700 premium all-in-one printer
My printer comes up with the message “Printer Failure problem with printer or ink system “ Not sure what to do to resolve this.
1 REPLY 1
Highlighted
HP Support Agent
HP Support Agent
5,675 5,646 337 377
Message 2 of 2
Flag Post
Hi @DavidM52-_,
I'd like to help!
Try the below suggestions-
Let's try a power reset on the printer
Reset the product
  • With the printer turned on, disconnect the power cord from the rear of the printer.
  • Unplug the power cord from the wall outlet.
  • Wait at least 60 seconds.
  • Plug the power cord back into the wall outlet.
  • Reconnect the power cord to the printer.
  • Turn the printer on. HP recommends plugging the printer directly into a wall outlet.
try updating the printer's firmware - HP Printers - Updating or Upgrading Printer Firmware
Remove and reinsert the ink cartridges
Remove and reinsert each ink cartridge.
  1. Open the door to access to the ink cartridges.
  2. Wait until the carriage stops moving before you continue.
  3. Push the ink cartridge to remove it, and then push it into its slot until it snaps into place.
    Animation of replacing the ink cartridges
  4. Repeat these steps for the other three ink cartridges.
  5. Close the ink cartridge access door.
Check the carriage for a printhead latch
Look at the carriage to see if it has a latch. The carriage is the part inside the printer that holds the printhead and cartridges. If the carriage does not have a latch (fixed printhead), then the only option is to service the printer.
  1. Open the door to access the cartridges.
  3. Look at the right side of the carriage to see if the carriage has a printhead latch (a handle that can be raised, which allows the printhead to be removed).
    • If your carriage has a printhead latch, continue to the next step.
    • If your carriage does not have a printhead latch (fixed printhead), skip to Service the printer. If the printhead is fixed, then there are no additional troubleshooting steps available.
Example of a carriage with a printhead latch
Example of a carriage without a printhead latch
Animations of carriage with a printhead latch
Carriage without a printhead latch
If the issue persists, I'd suggest you Contact HP in your region regarding the service options for your printer
And, Welcome to the HP Support Community.
Click the “Kudos, Thumbs Up" on the bottom right to say “Thanks” for helping
Reply
0 Kudos
Warning Be alert for scammers posting fake support phone numbers and/or email addresses on the community. If you think you have received a fake HP Support message, please report it to us by clicking on "Flag Post".
