cancel
Showing results for
Search instead for
Did you mean:
New member
2 1 0 0
Message 1 of 4
81
Flag Post
Printer HP4636 will not power on.
HP4636 All in One
Mac OS X 10.6 Snow Leopard and older
The HP4636 (All in One)  printer will not power on.
Printer was working fine for some years, however after a power down the printer will not power up anymore .
Also the  lights on the frontpanel remain off.
Finaly I have checked the power unit inside the printer and it seems okay. I measured 32 Volts and also 12 Volts after
connecting pin 2 and 3. This is how it should work, so the power unit seems okay.
What can be done ?
3 REPLIES 3
HP Support Agent
HP Support Agent
9,244 9,218 626 701
Message 2 of 4
Flag Post
Hi @HarryTigger,
I'd like to help!
Let's try a power reset on the printer
Reset the product
With the printer turned on, disconnect the power cord from the rear of the printer.
Unplug the power cord from the wall outlet.
Wait at least 60 seconds.
Plug the power cord back into the wall outlet.
Reconnect the power cord to the printer.
Turn the printer on. HP recommends plugging the printer directly into a wall outlet.
 Also, try updating the printer's firmware -HP Printers - Updating or Upgrading Printer Firmware
If the issue persists, I'd suggest you Contact HP in your region regarding the service options for your printer
And, Welcome to the HP Support Community.
Click the “Kudos, Thumbs Up" on the bottom right to say “Thanks” for helping
Reply
0 Kudos
Author
New member
2 1 0 0
Message 3 of 4
Flag Post
Thank you for the feedback
Your first sentence:
"With the printer turned on, disconnect the power cord from the rear of the printer."
The problem is however, the printer cannot be turned on! So your solution wil not work
Problem It started as follows:
1  The printer was switched ON
2  Printer refused to print.
3  I went into the menu (on the printer) but everything was locked nothing could be done anymore
4  So I decided to pull the power cord.
5  Hereafter the printer will not switch on.
6  Checked already the power unit inside and this seems okay.
Sofar I tried many combinations of powering on simultaneously pushing different switches on the printer panel.
Reply
0 Kudos
HP Support Agent
HP Support Agent
9,244 9,218 626 701
Message 4 of 4
Flag Post
As this is a hardware issue, I’d recommend you contact HP Phone Support in your region regarding service options for your printer.
Follow the instructions below to reach them:
1) Click on this link - https://support.hp.com/us-en/contact-hp
2) Select your product type below.
3) Enter the serial of your device.
4) Select the country from the drop-down.
5) Select the chat or get phone number options based on your preferences.
6)Fill the web-form and proceed further.
If you are having trouble navigating through the above options, it's most likely because the device is out of warranty. If yes? please send me a private message with the region you are contacting us from. Check next to your profile name, you should see a little blue envelope, please click on it.
Have a great day!
Reply
0 Kudos
Warning Be alert for scammers posting fake support phone numbers and/or email addresses on the community. If you think you have received a fake HP Support message, please report it to us by clicking on "Flag Post".
