    Windows update impacting certain printer icons and names. Microsoft is working on a solution.
    Click here to learn more
I received the error Printer failure-problem with the printer or print system. I performed a hard reset and checked for jams.
I noticed that the printer carriage won’t move freely either, any suggestions ?
1 REPLY 1
@RedWeb
Welcome to the HP support community.
I understand that you are getting printer failure errors, I am glad to assist you.
Check for obstructions in the carriage path
Clear obstructions from the carriage area inside the printer.
  1. With the printer on, disconnect the power cord from the rear of the printer.
  2. Open the door to access the carriage inside of the printer.
  3. Look in the carriage path for debris such as crumpled paper or dislodged labels, and then remove any that you find.
    Obstruction inside the printer
  4. Use your hand to move the carriage to each side, making sure it moves freely. If the carriage is stalled or docked to one side of the printer and you cannot move it, continue with these steps.
    Moving the carriage from side to side
  5. Close the carriage access door.
  6. Reconnect the power cord to the rear of the printer, and then turn the printer on.
Reset the printer
Reset the printer to recover from printer failures.
  1. With the printer turned on, disconnect the power cord from the printer.
  2. Unplug the power cord from the power source.
  3. Wait 60 seconds.
  4. Reconnect the power cord to a wall outlet and to the printer.
  5. NOTE: HP recommends plugging the printer directly into a wall outlet.
Here is the HP document for your reference:- Click here
Keep me posted.
To thank me for my efforts to help you, please mark my post as an accepted solution so that it benefits several others.
Cheers.
Sandytechy20
I am an HP Employee
