cancel
Showing results for
Search instead for
Did you mean:
    Fix HP Printer issue in macOS
    A [software component] will damage your computer message displays when printing or while installing - Click Here
    Fix Windows 10 Update Issues
    Resolve Windows 10 or update issues on HP computer or printer– Click Here
Note for common printer problems
Customers receiving the"will damage your computer" message along with others like "unable to access cups/tmp" or "'@%' cannot be opened" need to update their version of the macOS. Please check this article for more information: HP Printers - A [software component] will damage your computer message displays when printing or while installing (macOS) .
Highlighted
New member
1 0 0 0
Message 1 of 2
89
Flag Post
Printer head problem
officejet pro 8715
Why do ALL the print heads in OfficeJet Pro printers go "bad" after a couple of years?  I have at least three HP printers sitting in garage with bad print heads.  AND/OR why can't you get new replacement print heads that aren't more expensive than the freaking print costs in the first place????
Inquiring minds want to know!!!!
1 REPLY 1
Highlighted
Level 16
Level 16
33,112 26,493 2,406 8,709
Message 2 of 2
Flag Post
I have not had the same experience, and would say the suggestion that "ALL the print heads in Officejet Pro printers go bad after a couple years" is not true.  I have an HP Officejet Pro 8600 Plus I have used daily since 2013 and it is still going strong with no printhead issues.
One of the reasons the printheads are relatively expensive is that the replacement printheads include a complete set of four setup cartridges, which would cost ~$100 if purchased separately.
Bob Headrick,  HP Expert
I am not an employee of HP, I am a volunteer posting here on my own time.
If your problem is solved please click the "Accept as Solution" button
If my answer was helpful please click the "Thumbs Up" to say "Thank You"
Warning Be alert for scammers posting fake support phone numbers and/or email addresses on the community. If you think you have received a fake HP Support message, please report it to us by clicking on "Flag Post".
