×InformationFix Windows 10 Update Issues
Resolve Windows 10 related issues for your HP computers or printers by HP Windows 10 Support Center
- HP Community
- Printers
- Printer locked with blinking power / Stampante bloccata con ...
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Mute
- Printer Friendly Page
Printer locked with blinking power / Stampante bloccata con power lampeggiante
03-24-2021
03:12 PM
- last edited on
03-24-2021
03:16 PM
by
RodrigoB
la mia stampante m28w è bloccata. Quando premo il tasto On, la stampante si accende e la spia verde di accensione lampeggia. Anche la scritta HP sul display è intermittente. Ho provato ad effettuare le operazioni di rimozione del cavo di alimentazione ma la stampante non da segnali.
By google translate:
Operating System: Microsoft Windows 10 (64-Bit)
my m28w printer is frozen. When I press the On button, the printer turns on and the green power light blinks. HP on the display is also intermittent. I tried to remove the power cord but the printer does not give signals.
03-24-2021 03:16 PM
Hi sly71
Thank you for visiting our English HP Support Community. We advise you to post your question in English to insure a quick response for the Community.This can also help other users to take advantage of your post, in the case they have the same question.
Thank you for your understanding.
Regards,
03-24-2021 03:19 PM
my m28w printer is stuck. When I press the On button, the printer turns on and the green power light flashes. The HP word on the display is also intermittent. I have tried the steps to remove the power cord but the printer gives no signal.
03-28-2021 01:29 PM
We'll have to perform a reset on the Printer for this. I have sent you a private message, for more details that cannot be shared in a public post.
Please do check your inbox on the communities page for the private message.
Let me know if this helps.
If the information I've provided was helpful, give us some reinforcement by clicking the Accepted Solution button, that'll help us and others see that we've got the answers!
Thanks!
I am an HP Employee
03-28-2021 02:01 PM
I set up the printer and it seemed to work ok. I sent some files to print and it didn't print. I cleared the queue and reprinted and still did not print. I ran a few diagnostic apps on HP support and did not help. I pulled the power cord, waited and plugged in back in and the lights keep flashing with the B8047DF6 on the LCD screen. I did this multiple times not help. I reset the router, no help.
Please help or i will return to best buy.
Brad
Didn't find what you were looking for? Ask the community
