cancel
Showing results for
Search instead for
Did you mean:
    HP Solution Center Adobe Flash player error
    Please check this document to find the workaround solution for Print and Scan - HP Solution Center doesn't open
    Fix Windows 10 Update Issues
    Resolve Windows 10 or update issues on HP computer or printer– Click Here
New member
1 0 0 0
Message 1 of 2
78
Flag Post
Printer will not print, screen message: Supply Problem.
HP M180ns
Windows updated and I could not print about 1 month ago.  Rolled back update and the printer worked fine.  Windows updated again yesterday and now I cannot print along with a printer screen error message "Supply Problem".  HP needs to fix this!
I printed and scanned yesterday and everything worked just fine.  Yes I am using Genuine HP toner cartridges'.  Yes of course the warranty is out, purchased in early 2017.
I am using a HP computer, Monitor and printer.  If HP will not help to fix this then of course I will have to look at buying from the competition.
Tech support, are you going to help.
Contact me for phone information
Thanks
1 REPLY 1
HP Support Agent
HP Support Agent
16,698 16,679 1,307 1,318
Message 2 of 2
Flag Post
@Not_Happy2, Welcome to HP Support Community!
I have brought your issue to the attention of an appropriate team within HP. They will likely request information from you in order to look up your case details or product serial number. Please look for a private message from an identified HP contact. Additionally, keep in mind not to publicly post personal information (serial numbers and case details).
If you are unfamiliar with how the Forum's private message capability works, you can learn about that here.
Thank you for visiting the HP Support Community.
TEJ1602
I am an HP Employee
Reply
0 Kudos
Warning Be alert for scammers posting fake support phone numbers and/or email addresses on the community. If you think you have received a fake HP Support message, please report it to us by clicking on "Flag Post".
