Problem with printer or ink system
4 REPLIES 4
Hi @Nemos,
I see that you are facing an issue with your printer that has a ink system error.
To understand the issue and help you, please share the details listed below:
- Exact model number/product number(SKU number) of your HP Product (Click herefor information on how to find the model number/product number).
- May I know which application you are using to print?
- When was the last time your printer was working fine?
- Were there any changes made to your printer recently?
- May I know which devices are you using to print eg: Windows PC, Mac, or Smartphone (Android or iPhone)?
Note: Do not share any of your personal information such as serial, phone number, email ID, etc.
Take care and have a great day ahead!
Irwin6
HP Support
Irfan_06-Moderator
I am an HP Employee
Serial # CN25F2H0RD
SKU #CZ155-64001
office jet 6600 model H711g
I was printing heavily colored flyers and after 8 copies I received this message: Printer failure, there is a problem with the printer or ink system. I changed cartridges, turned off printer and turned back on.. no change in error message. Not sure what to do now.
My printer is 4 in 1 HP officer pro 8600 and I found out that there is ink leakage from the ink cartridge inside the printer, so am I able to fix it?
Hi @Nemos,
Thank you for sharing the above information.
A) Please follow the steps below to perform a power drain.
1) Take out the cartridges
2) Unplug the power cord from the printer & wall.
3) Press and hold the power button down for 15 seconds and release the power button, wait for about 30 seconds.
4) Plug the power cord back into the printer and wall, ensure the printer is plugged into the wall & not into a surge protector.
5) Insert the cartridges back into the printer.
Remove the cartridges > Unplug the power cord > Wait for 30 seconds > Plug the power cord back in > Insert the cartridges
B) Kindly refer to the steps on this link to update the printer firmware and let me know if that resolves the issue.
C) If the issue still persists, refer to the steps on this link to further troubleshoot.
Please mark this post as “Accepted Solution” if the issue is resolved and if you feel this reply was helpful click “Yes”.
I hope this helps.
Take care and have a good day
Irwin6
HP Support
Irfan_06-Moderator
I am an HP Employee
