To resolve issues with error EBS00P0013 on HP Smart App: Click here to view.
HP OfficeJet Pro 8715 All-in-One Printer
I've tried all the troubleshooting tips for an affected ink cartridge with a supply system problem and it still won't work.
HP office jet pro 8715 printer.
2 REPLIES 2
Hi @Gbos,
If you've tried all the usual troubleshooting steps for an "ink supply system" issue with your HP OfficeJet Pro 8715 and it's still not working, you might need to try a few more steps.
  • Check Ink Cartridges: Make sure the ink cartridges are installed correctly. Remove and reinsert them, ensuring they click into place securely.
  • Clean Contacts: Turn off the printer and unplug it. Remove the ink cartridges and gently clean the electrical contacts on both the cartridges and inside the printer with a soft, lint-free cloth. Be careful not to get the cloth too wet.
  • Reset Printer: Perform a hard reset by turning off the printer, unplugging it from the power source, waiting for about 60 seconds, and then plugging it back in and turning it on.
  • Update Firmware: Check if there’s a firmware update available for your printer. Sometimes, a firmware update can resolve issues related to ink cartridges and supply systems.
  • Replace Cartridges: If the problem persists, try using new or different ink cartridges to rule out the possibility of defective cartridges.
  • Check for Firmware Errors: Sometimes the issue can be related to the printer’s firmware. Check the printer’s control panel or the HP Smart app for any error messages or firmware updates.
I hope this helps.
Alden4
HP Support
Raj_05
HP Support Community Moderator
I have tried everything except update firmware.  How do I update firmware on an HP OfficeJet Pro 8715?
