cancel
Showing results for
Search instead for
Did you mean:
    HP Solution Center Adobe Flash player error
    Please check this document to find the workaround solution for Print and Scan - HP Solution Center doesn't open
    Fix Windows 10 Update Issues
    Resolve Windows 10 or update issues on HP computer or printer– Click Here
New member
1 0 0 0
Message 1 of 4
149
Flag Post
Stuck message of "Problem with the Printer or Ink System" ..won't print, stuck on this message
HP Officejet Pro 8600
No matter what I try the printer is stuck on  this message "There is a problem with the printer or ink system."  Turn printer off, then on.  If problem persists, contact HP."  I have tried everything for hours.  It is just stuck on this one comment on printer.
3 REPLIES 3
New member
2 2 0 0
Message 2 of 4
Flag Post
It looks it happened with latest firmware update: OJP8600_N911g-n_2011A... Tried with 3 different cyan cartridges (non original chip) and does not work..
Anyone have access to previous firmware ? I am trying to get
OJP8600_N911g-n_R1545A.dmg , but none of HP links does not work or requires ftp credentials.
Reply
0 Kudos
New member
2 2 0 0
Message 3 of 4
Flag Post
@MarkyMark4 did you solve issue ?
Reply
0 Kudos
New member
2 1 0 0
Message 4 of 4
Flag Post
Does yours say that only one of the colors is empty?  or whatever?  mine has a little red x at the top of my magenta color in the settings.  This is ridiculous since I spent 104 dollars on these ink cartridges...
Reply
0 Kudos
Warning Be alert for scammers posting fake support phone numbers and/or email addresses on the community. If you think you have received a fake HP Support message, please report it to us by clicking on "Flag Post".
