How do I fix my printer when it says there is a supply system problem?
1 REPLY 1
Hi @volleykruse,
When your HP printer displays a message indicating a supply system problem, it typically refers to an issue with the ink or toner cartridges. Here are some steps you can take to troubleshoot and resolve the problem.
  • Check Cartridge Installation: Ensure that all ink or toner cartridges are properly installed in their respective slots. Open the printer cover and inspect each cartridge to make sure they are securely in place.
  • Replace Cartridges: If the cartridges are old or running low on ink/toner, replace them with new ones. Make sure you're using genuine HP cartridges for the best compatibility and performance.
  • Clean Cartridge Contacts: Sometimes, dirt or debris can accumulate on the cartridge contacts, causing connection issues. Turn off the printer and gently clean the contacts on both the cartridges and inside the printer with a lint-free cloth or cotton swab lightly dampened with distilled water.
  • Reset Printer: Turn off the printer, unplug it from the power source, and wait for a few minutes. Then, plug it back in and turn it on. This can sometimes reset the printer and clear the error message.
  • Update Printer Firmware: Check for any available firmware updates for your HP printer. Updating the firmware can sometimes resolve compatibility issues and improve printer functionality.
  • Inspect for Jammed Paper: Even though the error message specifically mentions the supply system, a paper jam could trigger related errors. Check the printer for any jammed paper or obstructions in the paper path and remove them carefully.-
By following these steps, you should be able to troubleshoot and resolve the supply system problem on your HP printer.
I hope this helps.
Alden4
HP Support
Raj_05
HP Support Community Moderator
