cancel
Showing results for
Search instead for
Did you mean:
Common problems for INSTANT INK, HP+ PLANS: INK AND TONER
We would like to share some of the most frequently asked questions about Instant Ink. Check out this link: HP INSTANT INK, HP+ PLANS: INK AND TONER. .
Gotoexpert
New member
1 0 0 0
Message 1 of 2
92
Flag Post
There is a problem with the printer or ink system
HP Officejet Pro 8600
Microsoft Windows 7 (64-bit)
HP Officejet Pro 8600, Getting error: "There is a problem with the printer or ink system. Turn printer off, then on, if the problem persists, contact HP" I even turned printer off and on but I'm still getting same message.
Any ideas what is going on?
1 REPLY 1
Betty0610
HP Support Agent
HP Support Agent
14,859 14,841 770 618
Message 2 of 2
Flag Post
@Gotoexpert
Let's try to reset the Printer here:
Reset the product
  • With the printer turned on, disconnect the power cord from the rear of the printer.
  • Unplug the power cord from the wall outlet.
  • Wait at least 60 seconds.
  • Plug the power cord back into the wall outlet.
  • Reconnect the power cord to the printer.
  • Turn the printer on. HP recommends plugging the printer directly into a wall outlet.
Also, try connecting the Printer to a different wall outlet directly.
Also, try a firmware update: https://support.hp.com/in-en/document/c02919168
Let me know if this helps.
If the information I've provided was helpful, give us some reinforcement by clicking the Accepted Solution and Kudos buttons, that'll help us and others see that we've got the answers!
Thanks!
I am an HP Employee
Reply
0 Kudos
Warning Be alert for scammers posting fake support phone numbers and/or email addresses on the community. If you think you have received a fake HP Support message, please report it to us by clicking on "Flag Post".
