cancel
Showing results for
Search instead for
Did you mean:
    Check documents and videos on compatibility, FAQs, upgrade information and available fixes.Windows 11 Support Center.
user_zero
New member
1 0 0 0
Message 1 of 1
158
Flag Post
There is a problem with the printer or print system. Turn the printer Off, then On
HP Color LaserJet Pro M454dw
macOS 11.0 Big Sur
Product Description:       HP Color LaserJet Pro M454dw
Case Subject "There is a problem with the printer or print system. Turn the printer Off, then On. If you continue to get this message, contact support."
Spontaneous failure (no precipitating event). I have turned it off/on several times, unplugged it for 60 seconds, cold reset and factory reset. Toner levels all OK. It's just over a year old and sees very little use.
Warning Be alert for scammers posting fake support phone numbers and/or email addresses on the community. If you think you have received a fake HP Support message, please report it to us by clicking on "Flag Post".
