it is an HP officeJet Pro 7740
2 REPLIES 2
yes
Hi @Agua_2025,
Welcome to the HP Support Community!
Thanks for reaching out!
We're thrilled to have the opportunity to assist you and provide a solution.
I understand your HP OfficeJet Pro 7740 printer is showing “There is a problem with the supply system”. Let’s go through a few steps to troubleshoot this issue.
Restart the Printer
Turn off the printer and unplug it from the power source.
Wait for 60 seconds.
Plug it back in and power it on to see if the error clears.
Check Ink Cartridges
Open the ink cartridge access door.
Remove all cartridges carefully.
Inspect for any damage, leaks, or protective tape that hasn’t been removed.
Reseat each cartridge firmly in its correct slot until it clicks in place.
Check for Genuine HP Cartridges
Make sure you’re using original HP cartridges.
Non-HP or refilled cartridges can sometimes trigger supply system errors.
Inspect Cartridge Contacts
With the printer off, gently wipe the copper-coloured contacts on the cartridges and the contacts inside the printer with a lint-free cloth slightly dampened with distilled water.
Allow contacts to dry completely before reinserting cartridges.
Check for Paper or Debris
Ensure there’s no paper jam or debris inside the cartridge area that could block the mechanism.
Update Printer Firmware
Go to the printer’s Setup > Printer Maintenance > Update the Printer (if connected to WiFi).
Or download the latest firmware from the official HP Support website.
Reset the Printer
With the printer turned on, unplug the power cord from the back of the printer and from the wall.
Wait for 60 seconds, then plug it back in and power on.
This can clear residual supply system errors.
Test the Printer
Try printing or copying directly from the printer’s control panel to see if the error persists.
I hope this helps.
I'm glad I could help! 😊 If this resolved your issue, please mark it as "Accepted Solution" and click "Yes" on "Was this reply helpful?" Your feedback not only keeps us going but also helps others find the solution faster! 👍
Take care and have an amazing day ahead! 🚀
Best regards,
Kuroi_Kenshi
I am an HP Employee
