HP MFP281fdw
I have three of these printers, all purchased about three months apart.  All three have stopped turning on.  It is not a resetting issue.  It is not an outlet issue.  It is not the power cord (works fine to power other printers- etc.) usually after letting them sit a few hours, not plugged in, etc, we can get them to work.
All are less than 9 months of use after purchase when this begins.  Now they won’t power on at all. Suggestions? I keep trying to file a warranty claim and get disconnected each time after the bot verifies they are still under warranty.
I don’t know what else to do.
1 REPLY 1
@RSpencer
Welcome to the HP support community.
I have brought your issue to the attention of an appropriate team within HP. They will likely request information from you in order to look up your case details or product serial number. Please look for a private message from an identified HP contact. Additionally, keep in mind not to publicly post personal information (serial numbers and case details).
If you are unfamiliar with how the Community's private message capability works, you can learn about that here.
Thank you for visiting the HP Support Community.
Sandytechy20
I am an HP Employee
