What does “printer head problem” mean on a model 6970
1 REPLY 1
Hi @Betty8011,
I'd be happy to help you!
If you have already performed the steps from the document and the issue persists, it could be a hardware failure.
I would request you to contact our Support and our Support Engineers should be able to sort this out.
For that to happen, we will give you additional instructions/information via Private Message.
Please check your inbox on the forums page for the private message.
Please mark this post as Accepted Solution” if the issue is resolved and if you feel this reply was helpful click “Yes”.
Nal_NR-
HP Community Moderator
