A s.. product, which is always offline whenever you need to print something urgently
1 REPLY 1
Hello @Oleksii_Kuzniet
Try the procedures below:
https://support.hp.com/gb-en/document/ish_2026537-1681507-16
Best regards
Welcome to the Community, I am a volunteer and private messages will not be answered.
If the answer was helpful and/or you would like to say "thanks", Click on the button“Yes” Did I help solve the problem? Don't forget click “Accept as a solution” , If anyone has the same question, this solution might be helpful.
