HP ENVY 6452e All-in-One Printer
I have a envy 6452 and cannot print. There is a amber colored blinking light on the corner where you access the ink
cartridges and the Error message just keeps blinking.
1 REPLY 1
Hi @Vickie1000
I'd be happy to help you!
I understand that you are facing issues with the blinking lights.
Try updating firmware if not done already. Click here
The light bar blinks amber fast
The light bar blinks amber and the printer LEDs blink fast. This occurs when there is a serious printer error.
Light bar blinks amber fast
With the printer on, disconnect the power cord from the printer.
Unplug the power cord from the power source.
Wait 60 seconds.
Reconnect the power cord to the printer, and then plug the power cord directly into a wall outlet.
You may refer to this document  HP DeskJet, ENVY 6000, 6400 - Blinking lights and error codes | HP® Support for further assistance.
Hope this helps! Keep me posted for further assistance.
 Please mark this post as Accepted Solution” if the issue is resolved and if you feel this reply was helpful click “Yes”.
Nal_NR-
HP Community Moderator
