The message "There is a problem with the supply system..." appeared in my HP Officejet Pro 8720.  I installed a new cartridge, rebooted the PC and the printer, but the same message still appears.  I need help. Thanks!
2 REPLIES 2
You may need to clean the printhead.  possibly ink dried out and there is debris.
Something is stopping the ink from coming out.  Try cleaning the copper contacts.  I have no experience with 87xx but possibly the ink cannot get out due to a printhead problem.
Some printers have a printhead cleaning procedure.
To clean the printhead on an HP printer, access the printer settings through the HP Smart app, navigate to "Print Quality Tools," and select "Clean Printhead"; this will initiate a cleaning cycle where the printer will automatically run a cleaning process to clear any clogs in the printhead
Here is a general purpose article on cartridge problems.
This link shows cleaning a printhead but does not show how to clean dried ink
This is another type of printhead cleaning, different from the above but does not show cleaning dried out ink
Please let me know if any of this was helpful.
Hi,
Also, click the ink-drop icon on the printer screen and evaluate all ink levels..
Are all 4 ink cartridges have a sufficient ink level? note that all ink cartridges must have ink to print with your printer..
Click the Yes button to reply that the response was helpful or to say thanks.
If my post resolve your problem please mark it as an Accepted Solution 🙂
