My ph laser jet refuse to print
Laser jet managed flow MFP E82540
1 REPLY 1
@Bashar10, Welcome to the HP Support Community.
Thanks for reaching out about your query regarding the HP laser jet.
We're thrilled to have the opportunity to assist you and provide a solution. We hope our assistance has been helpful!
If your HP LaserJet Managed Flow MFP E82540 is refusing to print, you can try the following troubleshooting steps to identify and resolve the issue:
Troubleshooting Steps
  1. Check Printer Status:
    • Ensure the printer is turned on and ready. Check the printer's display for any error messages or notifications that might indicate the issue.
  2. Paper and Toner:
    • Verify that there is paper loaded in the input tray and that it is aligned correctly.
    • Check if the toner cartridges are properly installed and have sufficient toner.
  3. Connection Check:
    • For network-connected printers, ensure that the printer is properly connected to the network. You can verify this by printing a network configuration page from the printer’s control panel.
    • For USB connections, ensure the cable is securely connected to both the printer and the computer.
  4. Print Queue:
    • On your computer, check the print queue to see if documents are stuck. Clear the queue or cancel pending jobs and try printing again.
  5. Restart Printer:
    • Turn off the printer, wait a few seconds, and then turn it back on. This can resolve temporary connection or processing issues.
  6. Driver and Software Updates:
    • Make sure you have the latest printer drivers and software installed on your computer. Visit the HP Support site to download and install updates if necessary.
  7. Run HP Print and Scan Doctor:
    • Use the HP Print and Scan Doctor tool, which can help diagnose and resolve printing issues. It is available for download from the HP website.
  8. Check for Errors:
    • If there are any specific error codes or messages on the printer's display, refer to the printer's user manual or HP's online resources for specific troubleshooting guides related to the error.
I hope this helps!
Take care and have an amazing day!
If you would like to thank us for our efforts to help you, go to the public post and give us a virtual high-five by clicking on "Yes" for the question "Was this reply helpful?" below my message, followed by clicking on the "Accept as solution" on my public post.
Regards,
Meghana
