MY HP Smart Tank 7602 won't power up.  I made sure it was plugged in, I can hear the on button click, but no power.  It could be a power supply, but I don't know.  I place the order for it on February 10, 2025, it has to still be under warranty.  How do I get my money or new printer?
1 REPLY 1
Hi @Mark1085A,
Thank you for posting your query. I will be glad to help you.
I’m really sorry to hear your HP Smart Tank 7602 won’t power on, especially after just a few months of use. It’s incredibly frustrating when a new device fails, and I completely understand your concern about getting it replaced under warranty.
Let’s walk through what you can do next:
Troubleshooting Steps (If You Haven’t Already Tried These)
  1. Check the Power Source
    • Plug the printer directly into a wall outlet (not a surge protector).
    • Try a different outlet and power cable if available.
  2. yHard Reset
    • Unplug the printer.
    • Press and hold the Power button for 15 seconds.
    • Plug it back in and try turning it on again.
  3. Check for Signs of Life
    • If you hear a click or see a faint light, the issue may be with the power supply board or firmware.
If none of these work, it’s likely a hardware failure, and since you purchased it on February 10, 2025, your printer is still under HP’s standard 1-year warranty.
I hope this helps.
Take care and have an amazing day!
Did we resolve the issue? If yes, please consider marking this post as "Accepted Solution" and click "Yes" to give us a helpful vote - your feedback keeps us going!
Regards,
VikramTheGreat
