I have a laser jet printer 2755e which I need help with
2 REPLIES 2
Hi @Destine1,
Welcome to the HP Support Community!
Thanks for reaching out about your query regarding setting up your printer!
We're thrilled to have the opportunity to assist you and provide a solution.
Follow these instructions:
Contents: Ensure that you have the following:
  • HP LaserJet 2755e printer
  • Power cord
  • USB cable (if applicable)
  • Installation guides and documentation
  • Starter toner cartridge
Unpack the Printer:
  • Remove all packing materials from the printer, including any tapes and protective films.
  • Plug the power cord into the printer and an electrical outlet.
  • Turn on the printer.
  • Open the toner cartridge access door.
  • Remove the protective cover from the toner cartridge.
  • Insert the toner cartridge into the printer until it clicks into place.
  • Close the toner cartridge access door.
  • Open the paper tray.
  • Adjust the paper guides to fit your paper size.
  • Load the paper into the tray.
  • Close the paper tray.
Software Installation
Download Printer Software:
  • Go to the HP Support website and enter your printer model (LaserJet 2755e).
  • Download the latest drivers and software for your printer.
  • Run the downloaded software and follow the on-screen instructions to install the printer drivers.
Connect the Printer to Wi-Fi (wireless setup):
  • During the software installation process, select the wireless setup option.
  • Follow the on-screen instructions to connect the printer to your Wi-Fi network.
Alternatively, connect the printer using USB (wired setup):
  1. Connect the USB Cable:
    • Plug the USB cable into the printer and your computer.
    • Follow the on-screen instructions during the software installation to complete the setup.
Printer Configuration
  • After the installation, print a test page to ensure everything is working correctly.
  • On your computer, open the printer settings and select the option to print a test page.
  • If you want to print from mobile devices, download the HP Smart app from the app store on your mobile device.
  • Follow the instructions to add your printer to the app.
If you encounter any issues during the setup process, consult the user manual (HP LaserJet 2755e Printer - Setup Guide) provided with your printer.
I hope this helps.
I'm glad I could help! 😊 If this resolved your issue, please mark it as "Accepted Solution" and click "Yes" on "Was this reply helpful?" Your feedback not only keeps us going but also helps others find the solution faster! 👍
Take care and have an amazing day ahead! 🚀
Best regards,
Kuroi_Kenshi
I am an HP Employee
Hi @Destine1,
  • Power cord
Unpack the Printer:
I hope this helps.
Best regards,
Kuroi_Kenshi
I am an HP Employee
