cancel
Showing results for
Search instead for
Did you mean:
    HP Solution Center Adobe Flash player error
    Please check this document to find the workaround solution for Print and Scan - HP Solution Center doesn't open
    Fix Windows 10 Update Issues
    Resolve Windows 10 or update issues on HP computer or printer– Click Here
New member
1 0 0 0
Message 1 of 2
280
Flag Post
printer will not print with missing bowtie ink cartridge
HP C309a
Microsoft Windows 7 (64-bit)
Printer returning "The following ink cartridge appear to be mising or damaged <bow-tie> symbol.  As I understand it the bow-tie is the photo cartridge. I am not printing photos, and the just replaced all the other ones.  Is there a way to bypass the requirement to have ALL ink cartridges?
1 REPLY 1
Level 14
12,682 12,676 865 1,534
Message 2 of 2
Flag Post
Because of the printhead design you can not.
Please mark the post that solves your issue as "Accept as Solution".
I am a volunteer and do not work for HP.
0 Kudos
Warning Be alert for scammers posting fake support phone numbers and/or email addresses on the community. If you think you have received a fake HP Support message, please report it to us by clicking on "Flag Post".
