    Windows update impacting certain printer icons and names. Microsoft is working on a solution.
    Click here to learn more
HP Officejet 7612 Wide Format
macOS 10.12 Sierra
When I print double sided the second page is always upside down, how can I correct that
Hi! @Karelm51, Thanks for your response and time.
Kudos to you for trying out the steps.
Did you try the steps recommended in my previous thread?
Please try the steps recommended below.
From the printer control panel, open the Wireless menu, press Wireless Direct, and then make sure the setting is On (default).
Click the Apple menu (), and then click System Preferences.
Click Print & Scan (  ).
Click the plus sign () at the bottom of the left pane.
Under Nearby Printers, click the name of your printer.
Select the printer which has AirPrint listed next to it and remove the printer.
Also, refer this article to know how to configure air print.
Let me know if this helps!
Have a beautiful day ahead! 🙂
A4Apollo
I am an HP Employee
13 REPLIES 13
Hey there! @Karelm51, Welcome to HP forums.
I understand that you have issues printing double sided from your printer.
Don't worry I will try to help you out.
To avoid page ordering issues, load enough blank paper into the input tray to fully complete your print job.
Open the document that you want to print, click File, then click Print.
If no settings display, click Show Details.
Select the name of your printer in the Printer menu.
Select Paper Handling from the unnamed menu at the center of the window.
From the Pages of Print menu, select Odd Only.
Depending on your printer type, select one of the following settings from the Page Order menu:
Rear loading paper tray: Select Automatic
Front loading paper tray: Select Reverse
Click Print.
Refer this article to know more information about printing on Both Sides of the Paper.
Have a great day ahead! 🙂
A4Apollo
I am an HP Employee
This solution does not help. Why should I print the Uneven forst. This printer has a duplex mode!
The article you refer to does not help it shows windows that are different.
Please give ma a solution that aplys to this printer Officejet 7610
The printer prints in duplex mode as if  "short edge binding" is selected.   Wich is not the case it makes no difference wether I chose short edge binding or long edge binging. Pleas help.
Thanks for trying out the steps.
I have checked the specifications of your printer.
Do you have duplexer installed on your printer? The duplexer is an optional accessory on your printer.
Unless you have a duplexer installed on your printer you cannot print double side.
Refer the product specifications page for more information.
Also, refer this article to know how to print on Both Sides of the Paper.
I'll watch your reply!
A4Apollo
I am an HP Employee
Yes I have a duplexer on my printer.
@Karelm51, Thanks for your response.
As you mentioned you have a duplex on your printer.
Did you try the steps in my previous thread to configure printer printing on both sides article?
As you mentioned the issue still persists printing two-sided.
Please update the apple print drivers to OSX 5.0.
Use this link to update the printer drivers from apple website directly.
A4Apollo
I am an HP Employee
Hello Mr Robot,
I updatet the driver.
I did try your first advice to print only odd pages, the result is its prints page 1 and on the back page 3 upside down, I do'nt see how this can help me.
I read the article, the printer is connected with Lan, no airprint as far as I can see, printer = "officejet 7610 series"
I updated the driver first.
The printer prints double sided but the even pages are upside down, it make no difference if i choose short sidede binding or long sided binding.
I wonder if the printer is perhaps broken?
Karel
As you mentioned after updating the drivers the issue still persists.
Have you tried printing using a different application?
What application are you using to print?
Click on the 'Properties' button next to the selected printer, work through the tabs for the printer and see if there is an option for like "Binding Option". For the "portrait" mode you turn the page on the long edge, for 'landscape' you turn the page on the short edge. But you flip the page in portrait mode on the short edge and on the long edge for the landscape mode.
When you change the orientation mode of the page, you also need to change the binding edge.
You also need to check the paper size, source, scaling and layout settings for Acrobat and your selected printer.
 A two-sided option that allows you to switch between having to flip the page along the long edge or the short edge. If you go to where you selected your two-sided printing and change the printing to the other option, the second page will print with the correct orientation.
Have a pleasant day ahead! 🙂
A4Apollo
I am an HP Employee
Earlier I wrote that Airprint was not configured on this priner, I opened system configuration I saw that the printer is named as HP Series 7610 Airprintprinter  :smileyembarrassed:
I opened the webpage of the printer  en there too airprint is configured.
Maybe this is the problem?
How do I disable airprint?
I print from Word and Acrobat reader.
