macOS 10.13 High Sierra
I suddenly started receiving a "There is a problem with the printer or ink system" on Pro 8600 e-All-in-One printer. The message says to turn the printer on and off, which I've done, and also unplugged for hours and plugged back in. Same error occurs. This seemed to start when I replaced the Cyan (pink) ink cartridge with a regular HP ink cartridge, but not sure that's the root cause. Has anyone hit this error?
1 REPLY 1
Hi @Mikeabean,
I'd be happy to help you!
I understand that you are having issues with the ink system.
Try updating the firmware. Click here
This looks like a hardware issue. However, if you have performed all the steps from this document and still having issues, either the cartridges are faulty or the printer itself.
Hope this helps! Keep me posted for further assistance
Please mark this post as Accepted Solution” if the issue is resolved and if you feel this reply was helpful click “Yes”.
Nal_NR-Moderator
I am an HP Employee
