cancel
Showing results for
Search instead for
Did you mean:
The HP Calculator Community Message Board is moving. While we prepare for the move, we are unable to accept new postings. During the move, you can look for help from other users by visiting https://www.hpmuseum.org/ . Or if you need technical support for your calculator visit: HP Calculators. .
ArchivedThis topic has been archived. Information and links in this thread may no longer be available or relevant. If you have a question create a new topic by clicking here and select the appropriate board.
AlexFerraris
New member
1 0 0 0
Message 1 of 2
495
Flag Post
batterie branché , pas en charge / Battery plugged in, not charging
spectre xt
windows 7 HP Spectre xt 19.5V 3.33A
Mon chien a briser mon ac adapter il y a un ans ,
la semaine derniere je me suis procurer un ac adapter chez CAnada computer 19.5V 3.33A.
l'ordinateur fonctione quand il est branché mais indique 0% batterie branché , pas en charge.
avant l'incident du chien, l'ordinateur fonctionais parfaitement,  aucune faiblaisse de la baterie.
ordinateur jamais laisser sur alimentation en continue.
My Odg break ma ac adapter a year ago,
last week i got a new ac adapter 19.5V 3.33A at canada computer
the laptop work good when  is plugged in but shows 0% battery plugged in , not in charge.
Before the dog incident , the computer functioned perfectly with battery 100% functional.
computer never leave on continuous power ( plugged in the wall ) only for recharge de battery ....
Help please
1 REPLY 1
The_Fossette
HP Support Agent
HP Support Agent
29,155 21,825 1,961 2,158
Message 2 of 2
Flag Post
Hi @AlexFerraris,
Welcome to the HP Forums!
It is a great way to engage, post questions and find resolutions by working with specialists in the HP community.
I reviewed your post and I understand that the battery is not getting charged and you are getting plugged in not charging message.
I’d love to help!
Follow the below steps to fix this issue.
Reinstalled Microsoft ACPI-Compliant Control Method Battery under device manager.
Here is how you do it.
Step 1: Click the Windows “Start” button and right-click “Computer.”
Step 2: Click “Manage,” then “Device Manager.”
Step 3: Click the “Batteries” section. A list of devices will appear.
Step 4: Right-click the “Microsoft ACPI-Compliant Control Method Battery” device and click “Uninstall.”
Step 5: Click the “Action” menu item and “Scan for Hardware Changes” to reinstall the driver.
Restart the computer and the issue should be fixed.
If the issue persists, I recommend you update the bios the from the below link and test.
http://hp.care/2nikIQ9
Let me know how it goes and you have a good day ahead.
To simply say thanks, please click the "Thumbs Up" button to give me a Kudos to appreciate my efforts to help. If this helps, please mark this as “Accepted Solution” as it will help several others with the same issue to get it resolved without hassles.
Take care!
Cheers!
The_Fossette
I am an HP Employee
Was this reply helpful? Yes No
