×InformationWindows update impacting certain printer icons and names. Microsoft is working on a solution.
Click here to learn moreInformationNeed Windows 11 help?Check documents on compatibility, FAQs, upgrade information and available fixes.
- HP Community
- Desktops
- Desktop Audio
- Re: No Sound ! Sound Problem
6 REPLIES 6
07-13-2020 09:51 AM
Hi:
See if installing this W10 IDT audio driver works on your model. Restart the PC after installing the driver...
6.10.6504.0 July 03, 2015
07-13-2020 12:28 PM
Unfortunately, since that driver didn't install, I don't have any other suggestions for you to try.
Sometimes it works on older model desktop PC's, and sometimes not.
Since your PC is not supported for W10 by HP, you may want to consider reinstalling W7.
Didn't find what you were looking for? Ask the community
