    Windows update impacting certain printer icons and names. Microsoft is working on a solution.
    Click here to learn more
We have new content about Hotkey issue, Click here to check it out!
HP TouchSmart 610-1100me Desktop PC
Lost sound after resetting my pc, OS: Windows 10 Pro 64Bit
6 REPLIES 6
Hi:
See if installing this W10 IDT audio driver works on your model.  Restart the PC after installing the driver...
6.10.6504.0     July 03, 2015
ftp://ftp.hp.com/pub/softpaq/sp71501-72000/sp71717.exe
I can't download the file
it's showing a message that "
"This site can’t be reached"
tried 3-4 times
Works fine for me.
I just downloaded the file with no problem.
AFTER THIS MESSAGE INSTALLATION CLOSED AUTOMATICALLY
Unfortunately, since that driver didn't install, I don't have any other suggestions for you to try.
Sometimes it works on older model desktop PC's, and sometimes not.
Since your PC is not supported for W10 by HP,  you may want to consider reinstalling W7.
HI
Try this:-
Click settings
choose update & security
Click get help
type audio
choose yes to run a scan and see if this fixes your problems
Regards
Stephen
