HP Compaq Pro 6300 SFF
First time poster long time owner... I can't seem to find the pin out for the front panel for this machine. I know HP doesn't post the pin outs for any of their products especially the front panel header pin out, so I thought maybe one of you folks might have a solution to my dilemma. I know where the power on pins are just by happenstance rooting around with a flat blade screwdriver (old school yeah I know) but I don't want to root around and short the pins for the power LED and HD LED pins since they are polarity dependent. Any help would be greatly appreciated. Thanks in advance !
2 REPLIES 2
@Fairlyodd60,
Does this help?
This system is feedback driven thru Solution and Kudo flags. It's the only means of knowing if you have been served. Please click Accept as Solution, if your problem is solved. To say THANK YOU, press the "thumbs up symbol" to render a KUDO. You can render both Solution and KUDO..
HP Envy 8 5010 Tablet
(2) HP DV7t i7 3160QM 2.3Ghz 8GB
Printer -- HP OfficeJet Pro 8620 Legal
Custom Asus Z97D, I7-4790k, 16GB RAM, WIN10 Pro 64bit, ZOTAC GTX1080 AMP Extreme 3 fan 8GB RAM, 500GB SSD, Asus PB287 4k monitor, Rosewill Blackhawk case and 750W OCZ PSU.
Thank you for the response, but not this isn't the proper pin out for this board. I finally found the proper pin out by looking up the actual motherboard manufacturer's ID # . Here is the proper pin out for this board. Since it is a SFF motherboard I had to eliminate the pins that were not utilized since the pin out provided was only for sized tower model. Pin 1 HD LED + Pin 3 - HD LED Pin 2 PSLED + Pin 4 - PSLED Pin 7 Pwr Bn + Pin 6 Pwr Bn -
Only has 9 Pins for the Pro 6300 SFFOnly has 9 Pins for the Pro 6300 SFF6 Pins Used  for PWR PSLED HDDLED6 Pins Used for PWR PSLED HDDLED
