Windows 11 Support Center. -
- HP Community
- Desktops
- Desktop Hardware and Upgrade Questions
- HP ELITEDESK 800 G2 SFF Pinout: Power Switch, Power Led y H...
1 REPLY 1
08-21-2021 10:51 AM
@l080 -- do you have a question?
It seems like one of that cable is designed to connect to the 10 pins, and the other end is designed to connect to a "patch-panel" on the inside of the front-panel of the computer's case.
Are you considering moving that motherboard into a different computer case, and individually running two-wire cables to each of the power switch & HDD lamp & power lamp?
Ask the community
