Windows 11 Support Center. -
- HP Community
- Desktops
- Desktop Hardware and Upgrade Questions
- Need to Replace Power supply up Grade power to 700W from HP ...
1 REPLY 1
07-25-2022 08:00 PM
@Hakbali , welcome to the Community.
The motherboard in your computer is HP proprietary. It has a 4-pin power connector instead of a standard 24-pin ATX power connector. You will have to buy any PSU upgrade from HP. The most powerful PSU that HP has available is 500W (L05757-800). You can order it on HP PartSurfer by checking the box under "Add to Cart".
Please click the "Yes" button if my reply was helpful and "Accept as Solution" if your problem is Solved!!
I am not an HP Employee!!
Intelligence is God given. Wisdom is the sum of our mistakes!!
Ask the community
