Hp 24-df0014 All in one Desktop
I recently purchased a HP 24-df0014 All in one at best buy. I realized that it only had 256gb of storage but figured I'd add a hdd for more storage later. I purchased a seagate firecuda 1tb ssdhdd (2.5")and took apart the all in one to install my new hdd. Only then did I realize that there is no hardware for installing a hdd on this model. So, my question is, what are the part numbers for the hdd assembly and cable(s) for adding a hdd?
2 REPLIES 2
@Jesusthebarbari
Did you actually find a SATA data and power header ?
This system is feedback driven thru Solution and Kudo flags. It's the only means of knowing if you have been served. Please click Accept as Solution, if your problem is solved. To say THANK YOU, press the "thumbs up symbol" to render a KUDO. You can render both Solution and KUDO..
HP Envy 8 5010 Tablet
(2) HP DV7t i7 3160QM 2.3Ghz 8GB
Printer -- HP OfficeJet Pro 8620 Legal
Custom Asus Z97D, I7-4790k, 16GB RAM, WIN10 Pro 64bit, ZOTAC GTX1080 AMP Extreme 3 fan 8GB RAM, 500GB SSD, Asus PB287 4k monitor, Rosewill Blackhawk case and 750W OCZ PSU.
I did see a sata port. I didn't specifically see the power header, I assume there is one though. This is the same all in one that's offered with a 2.5" drive, with only a m.2 ssd. Ther is a spot for the hdd cage/assembly, but its empty in my (best buy) unit.
