Hi,
I have an old HP Pavillion Laptop 15-cc0xx and I wanted to see if it's possible to change its parts as it's pretty old and very slow I wanted to upgrade the parts. The parts I want to upgrade are
Motherboard - that has a CPU preinstalled and that's compatible with the laptop)
New HHD (possibly adding an SSD if that's an option)
current laptop has an i5 cPU so if I can get a good motherboard at a good price for i7 or i9 that would be the best option. I just want to know if replacing is a possibility and if so is there a certain model I should be looking at when buying the replaceable parts.
Thanks in advance!!
@Cameron20
Manual:
             http://h10032.www1.hp.com/ctg/Manual/c06525445.pdf
Note: Manual is for many series, some of them may not suitable for your machine because your machine is from the first generation of 15-cc machines.
Please use page 1 to work out which options you can take then go to page 50 to see which part # is the right one.
Regards.
BH
2 REPLIES 2
@Cameron20
Manual:
Regards.
BH
Thank you so much this is a great help!
