Windows 11 Support Center. -
- HP Community
- Desktops
- Desktop Hardware and Upgrade Questions
- Reset problem after CMOS battery replacement.
02-03-2022 10:15 AM
Running older HP. It stopped working. Replaced CMOS battery. Computer powers up and screen shows "F9 boot menu", "F10 setup".
Computer checks memory, then beeps and shows message: "Invalid electronic serial number 162-System Options Not Set. . . . Pressing F1 will record new configuration". No F keys do anything. Switching keyboard had no effect. Any help would be greatly appreciated!
02-03-2022 10:49 AM
hi
just this
https://support.hp.com/nz-en/document/c00477448
was this reply helpful , or just say thank you ? Click on the yes button
Please remember to mark the answers this can help other users
Desktop-Knowledge-Base
Windows 11 22h2 inside , user
02-04-2022 07:10 AM
Sorry, it is mentioned that if this does not work, that you have to contact HP
So probably not recoverable, you have to replace the motherboard
The computer being quite old, I advise you to go to a professional
Or maybe it's time to replace it
