Windows 11 Support Center. -
- HP Community
- Desktops
- Desktop Hardware and Upgrade Questions
- Spare parts for Omen Case
01-07-2022 03:08 AM
Hello, I need to find some spare parts for my Omen 30L (front glass panel, top bezel, side panel). There is a HP service where I can buy this parts?
Many thanks and regards
Solved! Go to Solution.
01-07-2022 06:58 AM
Hello
you have the HP parts store
but for many parts you have to look elsewhere
there is a list of partners, depending on your country, only, I find that there are less and less results
in the best case, you will have to search with the part number if you have, with a search engine
try the different options
https://parts.hp.com/hppartsIGSO/Default.aspx?mscssid=3958A19B0CD14F45A0FCFC7B7213B935
was this reply helpful , or just say thank you ? Click on the yes button
Please remember to mark the answers this can help other users
Desktop-Knowledge-Base
Windows 11 22h2 inside , user
01-07-2022 06:58 AM
Hello
